メインコンテンツにスキップ
Olympus Stylus 410 Slider Replacement
必要な工具と部品
  1. Olympus Stylus 410 Slider Replacement, Slider: 手順 1、 1の画像 1
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Slider Replacement: 手順 2、 1の画像 1
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Olympus Stylus 410 Slider Replacement: 手順 3、 1の画像 1
    • Lift the slider up until it comes off the upper track.
  4. Olympus Stylus 410 Slider Replacement: 手順 4、 1の画像 1
    • The slider should now be free from the body of the camera.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Jared Ruekberg
メンバー登録日: 04/15/10
33 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S6G13
5 メンバー
17のガイドは作成済み
2 件のコメント
Camera would not turn on nor lens extend. Took slider off per instructions and cleaned the switch and was able to rotate switch back and forth to turn camera on and off by hand. Reassembled slider and could turn camera on but not off. Disassembled again and find the rotating switch is permanently stuck in counter clockwise position and cannot be activated by hand. I do not want to force the switch because it did operate very easy. What can be the trouble?
rraff8300@sbcglobal.net
Richard Rafferty - 返信
Excellent instructions for removing stylist 410 slider. Hope you can help with my prior stuck switch problem.
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 20
今までの合計 3,546
