メインコンテンツにスキップ
Nokia E61i Headset Jack Replacement
必要な工具と部品
  1. Nokia E61i Headset Jack Replacement, Battery: 手順 1、 2の画像 1 Nokia E61i Headset Jack Replacement, Battery: 手順 1、 2の画像 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Headset Jack Replacement: 手順 2、 1の画像 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Headset Jack Replacement: 手順 3、 1の画像 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Headset Jack Replacement, Front Cover: 手順 4、 2の画像 1 Nokia E61i Headset Jack Replacement, Front Cover: 手順 4、 2の画像 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Headset Jack Replacement: 手順 5、 1の画像 1
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Headset Jack Replacement, Display: 手順 6、 2の画像 1 Nokia E61i Headset Jack Replacement, Display: 手順 6、 2の画像 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Nokia E61i Headset Jack Replacement: 手順 7、 2の画像 1 Nokia E61i Headset Jack Replacement: 手順 7、 2の画像 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Nokia E61i Headset Jack Replacement, Motherboard: 手順 8、 3の画像 1 Nokia E61i Headset Jack Replacement, Motherboard: 手順 8、 3の画像 2 Nokia E61i Headset Jack Replacement, Motherboard: 手順 8、 3の画像 3
    • Pull the green motherboard from the back casing.
  9. Nokia E61i Headset Jack Replacement, Connector Housing: 手順 9、 1の画像 1
    • Remove the connector housing by pushing and sliding it off the back panel.
    • Be very careful not to lose the small loose spring from behind the button or the small button itself.
  10. Nokia E61i Headset Jack Replacement, Headset Jack: 手順 10、 1の画像 1
    • Remove the headset jack from the housing by pulling it up.
終わりに
作成者
9人の作成者と共同で作成されました。
Christopher Patton
メンバー登録日: 04/07/11
208 ポイント
12のガイドは作成済み
チーム
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011人のメンバー
CPSU-WALTERS-S11S9G63
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 2,693
