メインコンテンツにスキップ
Disassembling Nokia E61i Antenna
必要な工具と部品
  1. Disassembling Nokia E61i Antenna, Battery: 手順 1、 2の画像 1 Disassembling Nokia E61i Antenna, Battery: 手順 1、 2の画像 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Disassembling Nokia E61i Antenna: 手順 2、 1の画像 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Disassembling Nokia E61i Antenna: 手順 3、 1の画像 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Disassembling Nokia E61i Antenna, Front Cover: 手順 4、 2の画像 1 Disassembling Nokia E61i Antenna, Front Cover: 手順 4、 2の画像 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Disassembling Nokia E61i Antenna: 手順 5、 1の画像 1
    • Remove the cover by pulling it up and off.
  6. Disassembling Nokia E61i Antenna, Display: 手順 6、 2の画像 1 Disassembling Nokia E61i Antenna, Display: 手順 6、 2の画像 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Disassembling Nokia E61i Antenna: 手順 7、 2の画像 1 Disassembling Nokia E61i Antenna: 手順 7、 2の画像 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Disassembling Nokia E61i Antenna, Motherboard: 手順 8、 3の画像 1 Disassembling Nokia E61i Antenna, Motherboard: 手順 8、 3の画像 2 Disassembling Nokia E61i Antenna, Motherboard: 手順 8、 3の画像 3
    • Pull the green motherboard from the back casing.
  9. Disassembling Nokia E61i Antenna, Antenna: 手順 9、 2の画像 1 Disassembling Nokia E61i Antenna, Antenna: 手順 9、 2の画像 2
    • After the logic board has been removed, there is nothing else securing the antenna to the back cover. Simply remove the antenna by pushing outward from the interior side.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Christopher Patton
メンバー登録日: 04/07/11
208 ポイント
12のガイドは作成済み
チーム
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011人のメンバー
CPSU-WALTERS-S11S9G63
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,959
