メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling Nokia 6086 Upper Back Cover
必要な工具と部品
  1. Disassembling Nokia 6086 Upper Back Cover, Battery: 手順 1、 1の画像 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
    FixBotに聞いてみる
  2. Disassembling Nokia 6086 Upper Back Cover: 手順 2、 3の画像 1 Disassembling Nokia 6086 Upper Back Cover: 手順 2、 3の画像 2 Disassembling Nokia 6086 Upper Back Cover: 手順 2、 3の画像 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    FixBotに聞いてみる
  3. Disassembling Nokia 6086 Upper Back Cover: 手順 3、 3の画像 1 Disassembling Nokia 6086 Upper Back Cover: 手順 3、 3の画像 2 Disassembling Nokia 6086 Upper Back Cover: 手順 3、 3の画像 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
    FixBotに聞いてみる
  4. Disassembling Nokia 6086 Upper Back Cover, Upper Back Cover: 手順 4、 1の画像 1
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
    FixBotに聞いてみる
  5. Disassembling Nokia 6086 Upper Back Cover: 手順 5、 2の画像 1 Disassembling Nokia 6086 Upper Back Cover: 手順 5、 2の画像 2
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
    FixBotに聞いてみる
  6. Disassembling Nokia 6086 Upper Back Cover: 手順 6、 2の画像 1 Disassembling Nokia 6086 Upper Back Cover: 手順 6、 2の画像 2
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
    FixBotに聞いてみる
  7. Disassembling Nokia 6086 Upper Back Cover: 手順 7、 3の画像 1 Disassembling Nokia 6086 Upper Back Cover: 手順 7、 3の画像 2 Disassembling Nokia 6086 Upper Back Cover: 手順 7、 3の画像 3
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
    FixBotに聞いてみる
終わりに
作成者
5人の作成者と共同で作成されました。
Andrea
メンバー登録日: 04/15/10
70 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S26G30
4 メンバー
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 74
今までの合計 2,530
