メインコンテンツにスキップ
Disassembling Nokia 6086 Top Front Cover
必要な工具と部品
  1. Disassembling Nokia 6086 Top Front Cover, Battery: 手順 1、 1の画像 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 6086 Top Front Cover: 手順 2、 3の画像 1 Disassembling Nokia 6086 Top Front Cover: 手順 2、 3の画像 2 Disassembling Nokia 6086 Top Front Cover: 手順 2、 3の画像 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Disassembling Nokia 6086 Top Front Cover: 手順 3、 3の画像 1 Disassembling Nokia 6086 Top Front Cover: 手順 3、 3の画像 2 Disassembling Nokia 6086 Top Front Cover: 手順 3、 3の画像 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Disassembling Nokia 6086 Top Front Cover, Top Front Cover: 手順 4、 1の画像 1
    • Close the phone.
    • Face the front cover forward.
  5. Disassembling Nokia 6086 Top Front Cover: 手順 5、 2の画像 1 Disassembling Nokia 6086 Top Front Cover: 手順 5、 2の画像 2
    • Locate the 4.5 mm notch at the top of the phone.
    • Place the iPod opening tool into the opening.
    • Slightly prop up the top section by lifting the tool.
  6. Disassembling Nokia 6086 Top Front Cover: 手順 6、 3の画像 1 Disassembling Nokia 6086 Top Front Cover: 手順 6、 3の画像 2 Disassembling Nokia 6086 Top Front Cover: 手順 6、 3の画像 3
    • Wedge the iPod opening tool between the top cover and the phone.
    • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
    • Repeat for both the left and the right sides of the phone.
    • Place the top cover aside once the top cover is completely disconnected from the phone.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Andrea
メンバー登録日: 04/15/10
70 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S26G30
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 2,280
