メインコンテンツにスキップ
Disassembling Nokia 3560 Charging Port and Power Connector
必要な工具と部品
  1. Disassembling Nokia 3560 Charging Port and Power Connector, Back Cover: 手順 1、 2の画像 1 Disassembling Nokia 3560 Charging Port and Power Connector, Back Cover: 手順 1、 2の画像 2
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Keypad: 手順 2、 1の画像 1
    • Lift the front case off of the phone body.
  3. Disassembling Nokia 3560 Charging Port and Power Connector: 手順 3、 2の画像 1 Disassembling Nokia 3560 Charging Port and Power Connector: 手順 3、 2の画像 2
    • Lift the keypad off of the phone.
  4. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 LCD Display: 手順 4、 1の画像 1
    • The screen is held to the body by six screws.
  5. Disassembling Nokia 3560 Charging Port and Power Connector: 手順 5、 1の画像 1
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  6. Disassembling Nokia 3560 Charging Port and Power Connector: 手順 6、 2の画像 1 Disassembling Nokia 3560 Charging Port and Power Connector: 手順 6、 2の画像 2
    • Insert a flat screwdriver between the black body and plastic layer.
  7. Disassembling Nokia 3560 Charging Port and Power Connector: 手順 7、 1の画像 1
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  8. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Logic Board: 手順 8、 1の画像 1
    • With the screws removed, the logic board can then be lifted out of the body by hand.
  9. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Charging Port and Power Connector: 手順 9、 2の画像 1 Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Charging Port and Power Connector: 手順 9、 2の画像 2
    • These two parts can be removed with your fingers.
    • Make sure not to bend the metal contacts.
終わりに
作成者
6人の作成者と共同で作成されました。
Sam Ryan
メンバー登録日: 04/18/10
1 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 30-39, Garner Spring 2010 Cal Poly, Team 30-39, Garner Spring 2010人のメンバー
CPSU-GARNER-S10S30G39
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 18
今までの合計 3,296
