はじめに
Removing the stand from the rest of the monitor allows you to access and replace parts inside the display assembly.
Before beginning this guide, prepare a clean, flat surface to use as a workstation. Avoid working over carpeting, as small screws are used and, if dropped, may be lost in the carpet.
パーツ
パーツは指定されていません。
  1. Place the monitor face down on a clean, flat surface. Place the monitor face down on a clean, flat surface.
    • Place the monitor face down on a clean, flat surface.
  2. Firmly remove the back panel of the stand by pulling it up and away from the monitor. Firmly remove the back panel of the stand by pulling it up and away from the monitor.
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  4. Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand. Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  5. Firmly grasp the stand enclosure with your hand and slide it to base of stand. Firmly grasp the stand enclosure with your hand and slide it to base of stand.
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  6. Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  7. Lift the the stand straight up to remove it. Lift the the stand straight up to remove it.
    • Lift the the stand straight up to remove it.
まとめ
Michela Upson
メンバー登録日: 2013年10月17日
107 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 11-36, Amido Fall 2013 Cal Poly, Team 11-36, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S11G36
5 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 423
