メインコンテンツにスキップ
Disassembling NEC LCD1770NX Monitor Enclosure
必要な工具と部品
  1. Disassembling NEC LCD1770NX Monitor Enclosure, Stand: 手順 1、 2の画像 1 Disassembling NEC LCD1770NX Monitor Enclosure, Stand: 手順 1、 2の画像 2
    • Place the monitor face down on a clean, flat surface.
  2. Disassembling NEC LCD1770NX Monitor Enclosure: 手順 2、 2の画像 1 Disassembling NEC LCD1770NX Monitor Enclosure: 手順 2、 2の画像 2
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. Disassembling NEC LCD1770NX Monitor Enclosure: 手順 3、 2の画像 1 Disassembling NEC LCD1770NX Monitor Enclosure: 手順 3、 2の画像 2
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. Disassembling NEC LCD1770NX Monitor Enclosure: 手順 4、 2の画像 1 Disassembling NEC LCD1770NX Monitor Enclosure: 手順 4、 2の画像 2
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. Disassembling NEC LCD1770NX Monitor Enclosure: 手順 5、 1の画像 1
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. Disassembling NEC LCD1770NX Monitor Enclosure: 手順 6、 2の画像 1 Disassembling NEC LCD1770NX Monitor Enclosure: 手順 6、 2の画像 2
    • Lift the the stand straight up to remove it.
  7. Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: 手順 7、 3の画像 1 Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: 手順 7、 3の画像 2 Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: 手順 7、 3の画像 3
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  8. Disassembling NEC LCD1770NX Monitor Enclosure: 手順 8、 3の画像 1 Disassembling NEC LCD1770NX Monitor Enclosure: 手順 8、 3の画像 2 Disassembling NEC LCD1770NX Monitor Enclosure: 手順 8、 3の画像 3
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  9. Disassembling NEC LCD1770NX Monitor Enclosure: 手順 9、 2の画像 1 Disassembling NEC LCD1770NX Monitor Enclosure: 手順 9、 2の画像 2
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  10. Disassembling NEC LCD1770NX Monitor Enclosure: 手順 10、 1の画像 1
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  11. Disassembling NEC LCD1770NX Monitor Enclosure: 手順 11、 3の画像 1 Disassembling NEC LCD1770NX Monitor Enclosure: 手順 11、 3の画像 2 Disassembling NEC LCD1770NX Monitor Enclosure: 手順 11、 3の画像 3
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  12. Disassembling NEC LCD1770NX Monitor Enclosure: 手順 12、 2の画像 1 Disassembling NEC LCD1770NX Monitor Enclosure: 手順 12、 2の画像 2
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  13. Disassembling NEC LCD1770NX Monitor Enclosure: 手順 13、 2の画像 1 Disassembling NEC LCD1770NX Monitor Enclosure: 手順 13、 2の画像 2
    • Pull the the metal casing off of the monitor to reveal the motherboards.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
John Patterson
メンバー登録日: 10/19/13
253 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 11-36, Amido Fall 2013 Cal Poly, Team 11-36, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S11G36
5 メンバー
7のガイドは作成済み
コメント 1 件
very helpful
Thank you
Richard Morgan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 5,766
