メインコンテンツにスキップ
Disassembling Motorola Q700 Sidekick Phone
必要な工具と部品
  1. Disassembling Motorola Q700 Sidekick Phone, Phone: 手順 1、 1の画像 1
    • When looking at the front of the phone, use the Plastic Opening Tool to pry off the four buttons located in each of the corners on the front.
  2. Disassembling Motorola Q700 Sidekick Phone: 手順 2、 1の画像 1
    • Turn the phone face-down. Remove the back cover, exposing the battery.
    • Use the Plastic Opening Tool to pry the battery out of the phone.
  3. Disassembling Motorola Q700 Sidekick Phone: 手順 3、 1の画像 1
    • Using the appropriate size Phillips screwdriver, unscrew the four screws located in each of the corners on the back of the device.
    • Although the battery is shown in this picture, please remember to make sure that it is removed in order to proceed with disassembly.
  4. Disassembling Motorola Q700 Sidekick Phone: 手順 4、 1の画像 1
    • After removal of the back screws, use the Plastic Opening Tool to carefully separate the top and bottom halves of the device.
  5. Disassembling Motorola Q700 Sidekick Phone: 手順 5、 1の画像 1
    • Using the appropriate size Phillips screwdriver, remove any screws that are attached or associated with the keypad and carefully remove keypad from the device.
  6. Disassembling Motorola Q700 Sidekick Phone: 手順 6、 1の画像 1
    • On the back of the device, you will see individual green and yellow technical pieces. Remove those two pieces from the phone with your fingers and set aside.
  7. Disassembling Motorola Q700 Sidekick Phone: 手順 7、 1の画像 1
    • You should now have all of the pieces separated and disassembled for your device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Rich
メンバー登録日: 04/08/13
125 ポイント
6のガイドは作成済み
チーム
SUNY Cortland, Team 1-4, Getto Spring 2013 SUNY Cortland, Team 1-4, Getto Spring 2013人のメンバー
SUNYCORT-GETTO-S13S1G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 15
今までの合計 678
