メインコンテンツにスキップ
Disassembling Motorola Defy XT
必要な工具と部品
  1. Disassembling Motorola Defy XT, Disassembling Motorola Defy XT: 手順 1、 1の画像 1
    • Switch off the mobile.
  2. Disassembling Motorola Defy XT: 手順 2、 1の画像 1
    • Unlock the back case before open.
  3. Disassembling Motorola Defy XT: 手順 3、 1の画像 1
    • Remove the battery
    • Remove the memory card
    • Remove the Sim card
  4. Disassembling Motorola Defy XT: 手順 4、 2の画像 1 Disassembling Motorola Defy XT: 手順 4、 2の画像 2
    • Remove 6 screws
    • Tear off a part of label
    • Release the usb cover
  5. Disassembling Motorola Defy XT: 手順 5、 1の画像 1
    • Open the green case part by yours fingernail from left side to the right side with the usb socket
    • Be care of your labels
    • If you want to repair the SIM card slot legs, be sure no short circuits in 6 legs.
  6. Disassembling Motorola Defy XT: 手順 6、 2の画像 1 Disassembling Motorola Defy XT: 手順 6、 2の画像 2
    • To release the PCB for cleaning the Display the the touch screen, remove 2 PARTS by fingernail.
    • 1. Touchscreen adapter
    • 2. Sticker between the touchscreen PCB & mobile PCB
    • Remove the mobile PCB much careful form top right. Be care the touchscreen circuits.
  7. Disassembling Motorola Defy XT: 手順 7、 3の画像 1 Disassembling Motorola Defy XT: 手順 7、 3の画像 2 Disassembling Motorola Defy XT: 手順 7、 3の画像 3
    • You can use a cloth, USB vacuum cleaner (be careful of the components in the green case), and adhesive tape to remove all the dust.
    • That finger pin is left by the Motorola Support Center in Hong Kong!!
    • You can also clean the camera lens on PCB
  8. Disassembling Motorola Defy XT: 手順 8、 1の画像 1
    • Remember to put all parts back and insert the touchscreen plugs slightly.
    • Put the green case back, make sure all locks is conneted
  9. Disassembling Motorola Defy XT: 手順 9、 1の画像 1
    • You can test the mobile before screw.
    • After insert the memory card, SIM card and battery, switch on the phone
    • Test call in and call out, also check the speaker
    • Open the map Apps to test Wifi and GPS
    • Bluetooth file transfer
    • Camera test and save in sd card
    • Check the sd card files
    • Try to connect with PC
  10. Disassembling Motorola Defy XT: 手順 10、 3の画像 1 Disassembling Motorola Defy XT: 手順 10、 3の画像 2 Disassembling Motorola Defy XT: 手順 10、 3の画像 3
    • If all works, remove the SIM card and battery.
    • Recheck the label is it on the top of the green case
    • Screws up all 6 screws
    • Put back all battery and SIM card
    • Close the back case and lock it
    • Close the USB cover
    • Done
  11. Disassembling Motorola Defy XT: 手順 11、 3の画像 1 Disassembling Motorola Defy XT: 手順 11、 3の画像 2 Disassembling Motorola Defy XT: 手順 11、 3の画像 3
    • If you want to explore what inside of the battery with PCB. Here is the step to follow.
    • Remove the label
    • Remove the black rubber
    • Tear the battery by hand (Be patient to repeat it many time) ***do not use any metal tools to cut it out!!
    • Also you can tear PCB by hand
  12. Disassembling Motorola Defy XT: 手順 12、 1の画像 1
    • Remove the black rubber Tear the battery by hand (Be patient to repeat it many time)
  13. Disassembling Motorola Defy XT: 手順 13、 1の画像 1
    • ***do not use any metal tools to cut it out!!
  14. Disassembling Motorola Defy XT: 手順 14、 1の画像 1
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Wing Nga PANG
メンバー登録日: 08/25/14
151 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 945
