この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This is ONLY a prerequisite guide to remove the LCD shield plate in the Motorola Cliq.
必要な工具と部品
Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
Turn the phone over and slide out the keyboard.
Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard.
ある他の人がこのガイドを完成しました。
