メインコンテンツにスキップ
Disassembling Motorola Cliq LCD Shield Plate
必要な工具と部品
  1. Disassembling Motorola Cliq LCD Shield Plate, Battery: 手順 1、 2の画像 1 Disassembling Motorola Cliq LCD Shield Plate, Battery: 手順 1、 2の画像 2
    • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
  2. Disassembling Motorola Cliq LCD Shield Plate: 手順 2、 2の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 2、 2の画像 2
    • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
  3. Disassembling Motorola Cliq LCD Shield Plate, Rear Casing: 手順 3、 3の画像 1 Disassembling Motorola Cliq LCD Shield Plate, Rear Casing: 手順 3、 3の画像 2 Disassembling Motorola Cliq LCD Shield Plate, Rear Casing: 手順 3、 3の画像 3
    • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
    • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
  4. Disassembling Motorola Cliq LCD Shield Plate: 手順 4、 1の画像 1
    • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
  5. Disassembling Motorola Cliq LCD Shield Plate: 手順 5、 3の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 5、 3の画像 2 Disassembling Motorola Cliq LCD Shield Plate: 手順 5、 3の画像 3
    • Turn the phone over and slide out the keyboard.
    • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
    • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
    • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
  6. Disassembling Motorola Cliq LCD Shield Plate: 手順 6、 1の画像 1
    • Carefully separate the back casing from the rest of the phone.
  7. Disassembling Motorola Cliq LCD Shield Plate: 手順 7、 2の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 7、 2の画像 2
    • Gently pry ZIF connector upwards using the flat end of a spudger tool.
    • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
    • You may need adhesive to keep your power cable in place when reassembling your phone.
  8. Disassembling Motorola Cliq LCD Shield Plate: 手順 8、 3の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 8、 3の画像 2 Disassembling Motorola Cliq LCD Shield Plate: 手順 8、 3の画像 3
    • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
    • The rear casing and the rest of the phone should now be completely separated.
  9. Disassembling Motorola Cliq LCD Shield Plate, Motherboard: 手順 9、 2の画像 1 Disassembling Motorola Cliq LCD Shield Plate, Motherboard: 手順 9、 2の画像 2
    • Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard.
  10. Disassembling Motorola Cliq LCD Shield Plate: 手順 10、 2の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 10、 2の画像 2
    • Pry the orange keyboard connector from its socket on the motherboard using the edge of the plastic opening tool.
  11. Disassembling Motorola Cliq LCD Shield Plate: 手順 11、 3の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 11、 3の画像 2 Disassembling Motorola Cliq LCD Shield Plate: 手順 11、 3の画像 3
    • Carefully grab the sides of the motherboard with your fingers and remove it from the phone.
  12. Disassembling Motorola Cliq LCD Shield Plate, LCD Shield Plate: 手順 12、 1の画像 1
    • Remove the ten 3.0 mm T4 Torx screws near the black display cable.
  13. Disassembling Motorola Cliq LCD Shield Plate: 手順 13、 3の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 13、 3の画像 2 Disassembling Motorola Cliq LCD Shield Plate: 手順 13、 3の画像 3
    • Orient the phone so that the edge closest to the camera points towards you and slide out the keyboard.
    • Wedge the tip of a spudger between the keyboard and the display assembly below the camera.
    • With steady pressure, pry the keyboard away from the display assembly.
    • The keyboard and display assembly are glued together, so expect some resistance.
    • Do not completely separate the keyboard and display assembly because the display flex cable still connects them.
  14. Disassembling Motorola Cliq LCD Shield Plate: 手順 14、 3の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 14、 3の画像 2 Disassembling Motorola Cliq LCD Shield Plate: 手順 14、 3の画像 3
    • Grab the display flex cable and gently push it through the notch it is coming out of.
  15. Disassembling Motorola Cliq LCD Shield Plate: 手順 15、 3の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 15、 3の画像 2 Disassembling Motorola Cliq LCD Shield Plate: 手順 15、 3の画像 3
    • Wedge a plastic opening tool underneath one of the metal panels on the underside of the display assembly.
    • Pry upwards and remove the metal panel.
    • Repeat this step for the second metal panel located on the opposite side of the phone.
  16. Disassembling Motorola Cliq LCD Shield Plate: 手順 16、 1の画像 1
    • Remove the four 3.0 mm T4 Torx screws at the corners of the phone.
  17. Disassembling Motorola Cliq LCD Shield Plate: 手順 17、 3の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 17、 3の画像 2 Disassembling Motorola Cliq LCD Shield Plate: 手順 17、 3の画像 3
    • Wedge a plastic opening tool between the edge and the black pastic cover on the underside of the display assembly.
    • Run the plastic opening tool along the edges to separate the black plastic cover from the display assembly.
    • Remove the black plastic cover.
  18. Disassembling Motorola Cliq LCD Shield Plate: 手順 18、 1の画像 1
    • Remove the six 3.0 mm T4 Torx screws that align on the phone's sides.
  19. Disassembling Motorola Cliq LCD Shield Plate: 手順 19、 2の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 19、 2の画像 2
    • Insert a plastic opening tool between the LCD shield plate and a corner of the keyboard slider plate.
    • Pry apart the keyboard slider plate and LCD shield plate.
    • Do not completely separate them: the keyboard slider plate is still connected to the LCD shield plate via the display flex cable.
  20. Disassembling Motorola Cliq LCD Shield Plate: 手順 20、 2の画像 1 Disassembling Motorola Cliq LCD Shield Plate: 手順 20、 2の画像 2
    • Pry the display flex cable from its connector on the LCD shield plate with a plastic opening tool.
    • Separate the display flex cable from the LCD cover plate.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Tony Tran
メンバー登録日: 04/14/13
64 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 10-42, Amido Spring 2013 Cal Poly, Team 10-42, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G42
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 395
