メインコンテンツにスキップ
Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case
必要な工具と部品
  1. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: 手順 1、 2の画像 1 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: 手順 1、 2の画像 2
    • Turn the speaker face down, so the connector side is up.
    • Remove the four #2 Philips screws on the back plate.
  2. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 手順 2、 1の画像 1
    • Remove the foam insert to expose the two spade connectors.
    • Carefully separate the connectors
  3. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 手順 3、 2の画像 1 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 手順 3、 2の画像 2
    • Turn the speaker so the grill side is up.
    • Remove the four screws on the grill. I had to use a t-10 Torx bit to remove them.
    • The grill is not glued on, but may require a bit of prying to remove.
  4. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 手順 4、 2の画像 1 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 手順 4、 2の画像 2
    • Remove the four silver bolts holding the speaker in place. These bolts also have threads inset for the grill screws to fit into.
    • This is a pretty quick and easy teardown, not too many parts in this one. The meyer speaker's part number is ST-164. It's a 16 Ohm driver.
終わりに
4 の人々がこのガイドを完成させました。
RoggeSound
メンバー登録日: 06/05/10
2,345 ポイント
1ガイドが承認済み
2 件のコメント
So I took one of my MM-4 apart because something was rattling. Turns out it has a loose magnet assembly. It must have been dropped in shipping.
Garrett McWilliams - 返信
Do you by any chance still have it?
I have two of them already and with some zipties and rubber they sound great again…
Would you by any chance ship the broken driver over to me?
Jan Marius -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 6,771
