はじめに
In order to repair items such as your window regulators or door lock vacuum actuators, and to properly lubricate your lock mechanisms, you will need to pull your door panel. This is not difficult, but there are some little tricks and "hidden" screws that can make it challenging the first time. Learn to properly remove your panel with this guide. This will allow you to easily move on to the more important projects lying behind the panel.
必要な工具と部品
Use a finger to push the tab that holds the trim piece to the crank out until it clears the crank.
Pull trim toward the knob on the crank to release the trim.
The trim piece will release from the peg at the base of the crank. The crank will now slide off.
When reassembling the manual window crank, make sure the tapered end of the washer is facing away from the door.
Using a wide pry tool, like this trim removal tool, go around the edge of the panel between it and the metal part of the door. You will find it held in place by plastic clips. Gently pry each clip out all the way around.
On an older car like the W123, there will likely be some broken clips. Some times, panels are being held in place by only two or three clips.
Pictured is the back of your door panel once removed. Notice the white plastic clips around the edge. Notice that many are missing. There should be several more on this door. Also, notice that some are broken.
Once the panel is removed, there should be a plastic vapor barrier between the panel and the door shell. This will need to be removed. If removed gently, it may be able to be reused. Otherwise, replace it with any thick plastic and 3M Spray Adhesive or contact cement. (Not pictured)
This is a list of the major components within the door (front passenger side shown):
Window regulator (note, the rear window regulators are designed differently and are not immediately visible)
Door lock vacuum actuator, early style (does not apply to driver's door, which is equipped with the master vacuum switch instead, see attached picture). On later W123's, the actuators are in similar locations but look different.
Door pull
Door latch and lock mechanisms
Master vacuum switch (driver's door). Note that on later models the master switch will be oriented vertically instead of horizontally.
Do you know how to get the metal looking ring around the lock knob without ruining it by any chance?
I am not Sure that piece removes easily. It may be bonded to the panel.
Are you talking about the lock knob seen in step 1? If so, just unscrew the knob.
I would safely assume the question is in regard to the chrome ring surrounding the lock knob as stated. I believe that ring is permanently attached to the door panel. I will take another look as I have to service all the of doors on my mercedes.
42 の人々がこのガイドを完成させました。
2 件のコメント
W114 is similar, except clips are metal. On the coupe, there is also a small screw holding in the lock lever chrome surround (there is no lock stem type knob in the coupe).
