メインコンテンツにスキップ
Disassembling Marshall MS-2 Partner Circuit Board
必要な工具と部品
  1. Disassembling Marshall MS-2 Partner Circuit Board, Disassembling Marshall MS-2 Micro Amp Case Disassembly: 手順 1、 1の画像 1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Partner Circuit Board: 手順 2、 3の画像 1 Disassembling Marshall MS-2 Partner Circuit Board: 手順 2、 3の画像 2 Disassembling Marshall MS-2 Partner Circuit Board: 手順 2、 3の画像 3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Partner Circuit Board: 手順 3、 2の画像 1 Disassembling Marshall MS-2 Partner Circuit Board: 手順 3、 2の画像 2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Partner Circuit Board: 手順 4、 1の画像 1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  5. Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: 手順 5、 2の画像 1 Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: 手順 5、 2の画像 2
    • Use a 9/16" socket to remove the nut around the headphone jack. Be careful to not lose the washer.
  6. Disassembling Marshall MS-2 Partner Circuit Board: 手順 6、 1の画像 1
    • Remove the 7/16" phillips head screw.
  7. Disassembling Marshall MS-2 Partner Circuit Board: 手順 7、 1の画像 1
    • Grab the headphone jack from inside the case and pull it toward the speaker until you can fully remove it from the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
MacKinley
メンバー登録日: 10/22/13
816 ポイント
5のガイドは作成済み
チーム
University of Maryland, Team 1-1, Shastany Fall 2013 University of Maryland, Team 1-1, Shastany Fall 2013人のメンバー
UMD-SHASTANY-F13S1G1
3 メンバー
5のガイドは作成済み
1件のガイドコメント
There Is a toroidal transformer inside ?
Jack redmond - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 6
過去 30 日: 11
今までの合計 2,041
