メインコンテンツにスキップ
Disassembling Macintosh IIsi Floppy Drive
必要な工具と部品
  1. Disassembling Macintosh IIsi Floppy Drive, Top Case: 手順 1、 2の画像 1 Disassembling Macintosh IIsi Floppy Drive, Top Case: 手順 1、 2の画像 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Floppy Drive: 手順 2、 3の画像 1 Disassembling Macintosh IIsi Floppy Drive: 手順 2、 3の画像 2 Disassembling Macintosh IIsi Floppy Drive: 手順 2、 3の画像 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: 手順 3、 3の画像 1 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: 手順 3、 3の画像 2 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: 手順 3、 3の画像 3
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Floppy Drive: 手順 4、 3の画像 1 Disassembling Macintosh IIsi Floppy Drive: 手順 4、 3の画像 2 Disassembling Macintosh IIsi Floppy Drive: 手順 4、 3の画像 3
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
    Excellent pictures and easy guide! Thank you very much. My IISI floppy drive started flawlessly after 25y and the disk could be read. however it did it just once. Then I could not eject it any more. It did not work anymore. Can I replace it with a Sony MPF 920E? What type of cableadapter do I need
    Georgu Jörg - 返信
    Generally these old Macs only work with Apple style floppy drives, they use both a different cable and signaling standard than PC drives. If your drive isn't ejecting your best bet is to either replace it with a similar 1.44MB "SuperDrive", or service the drive. There are some good videos floating around the web about how to repair and maintain these old drives, and it isn't actually too hard to disassemble and clean them.
    Chris Green -
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Chris Green
メンバー登録日: 10/11/09
36,978 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,535のガイドは作成済み
コメント 1 件
Hi there, I have IIsi Mac but the driver couldn’t read all the floppy dsks!
note: it was stored for more than 7 years.
Q. How can I clean it and what is the suitable cleaning items you recommend?
thanks.
Abdulaziz - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 2,760
