はじめに
The Macintosh IIsi came with a red-ribbon 1.44MB "SuperDrive" (and yes, just like DVD-Burning "SuperDrives" this was the best available option)
必要な工具と部品
The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
Push these two tabs out, and lift the drive up.
Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
This drive was manufactured by Sony in 1990.
Excellent pictures and easy guide! Thank you very much. My IISI floppy drive started flawlessly after 25y and the disk could be read. however it did it just once. Then I could not eject it any more. It did not work anymore. Can I replace it with a Sony MPF 920E? What type of cableadapter do I need
Generally these old Macs only work with Apple style floppy drives, they use both a different cable and signaling standard than PC drives. If your drive isn't ejecting your best bet is to either replace it with a similar 1.44MB "SuperDrive", or service the drive. There are some good videos floating around the web about how to repair and maintain these old drives, and it isn't actually too hard to disassemble and clean them.
2 の人々がこのガイドを完成させました。
