メインコンテンツにスキップ
はじめに
You will learn how to remove the scroll wheel from mount.
パーツ
パーツは指定されていません。
  1. Hold the mouse so that the bottom is facing up.
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    باز کردن پیچ زیر موس
    h sh - 返信
    There may be a sticker covering the screw hole.
    Eric Jensen - 返信
  2. Place the mouse so that the bottom is resting against a hard surface. Lift the top cover of the mouse gently, and remove it.
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    جدا کردن قاب رو و زیر موس
    h sh - 返信
    The cover doesn’t lift straight up on my model - once you raise the back slightly as shown, gently pull it backward (parallel to the table top, away from the cord) to disengage two plastic clips that connect the bottom to the top.
    Eric Jensen - 返信
  3. Locate the scroll wheel on the mouse. Grab the scroll wheel with your thumb and index finger. Gently lift up, to remove the scroll wheel from the mouse.
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    خارج کردن چرخ اسکرول موس
    h sh - 返信
    Good information!
    My mouse is like new again.
    Many thanks
    Arie Dekker - 返信
  4. Locate the spring on the scroll wheel, and carefully remove the spring. Locate the spring on the scroll wheel, and carefully remove the spring.
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    نحوه قرارگیری فنر سمت راست چرخ اسکرول
    h sh - 返信
  5. Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down. Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    h sh - 返信
  6. Use the images to locate where the resistance spring is. This spring will easily fall off. Grab the scroll wheel and its mount and gently pull them apart.
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
    نحوه قرارگیری فلز سمت چپ چرخ اسکرول
    h sh - 返信
終わりに
13 の人々がこのガイドを完成させました。
Maximilian Betkowski
メンバー登録日: 2013年01月11日
232 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S5G14
5 メンバー
7のガイドは作成済み
7 件のコメント
Excellent! I took an MBJ58 apart to remove accumulated gunk, and the resistance spring jumped onto my worktable before I noticed where it came from. Thanks for the help, well done!
Marty Swartz - 返信
Heh, me too. Couldn't for the life of me figure out how it went back in. Thanks for the guide!
Steve Bennett - 返信
Same thing happened to me...saved me a trip to the store for a new mouse!!
thanks for taking the time to post these photos!
Bill McFarland - 返信
huh, thank you very much, amazing guide, the only for this product in Internet , and amazingly accurate
leartzajmi - 返信
the resistence spring falled off on mine how do i out it back on help
Tay Carr - 返信
سلام، عالی بود، خیلی ممنون
hi, very good Education. very thanks
h sh - 返信
Guida utile e ben dettagliata che mi ha consentito di prolungare la vita del mio mouse e soprattutto capire come sistemare le molle !
Fulvio Serlenga - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 29
今までの合計 5,707
