メインコンテンツにスキップ
Disassembling Logitech MBJ58 Mouse Scroll wheel from mount
必要な工具と部品
  1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Top cover: 手順 1、 1の画像 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 手順 2、 2の画像 1 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 手順 2、 2の画像 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 手順 3、 3の画像 1 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 手順 3、 3の画像 2 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 手順 3、 3の画像 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: 手順 4、 2の画像 1 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: 手順 4、 2の画像 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: 手順 5、 2の画像 1 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: 手順 5、 2の画像 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 手順 6、 3の画像 1 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 手順 6、 3の画像 2 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 手順 6、 3の画像 3
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
終わりに
14 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Maximilian Betkowski
メンバー登録日: 01/11/13
238 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S5G14
5 メンバー
23のガイドは作成済み
7件のガイドコメント
Excellent! I took an MBJ58 apart to remove accumulated gunk, and the resistance spring jumped onto my worktable before I noticed where it came from. Thanks for the help, well done!
Marty Swartz - 返信
Heh, me too. Couldn't for the life of me figure out how it went back in. Thanks for the guide!
Steve Bennett - 返信
Same thing happened to me...saved me a trip to the store for a new mouse!!
thanks for taking the time to post these photos!
Bill McFarland - 返信
huh, thank you very much, amazing guide, the only for this product in Internet , and amazingly accurate
leartzajmi - 返信
the resistence spring falled off on mine how do i out it back on help
Tay Carr - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 70
今までの合計 8,286
