メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling Logitech G515 Lightspeed TKL
必要な工具と部品
  1. Disassembling Logitech G515 Lightspeed TKL, Remove keycaps: 手順 1、 2の画像 1 Disassembling Logitech G515 Lightspeed TKL, Remove keycaps: 手順 1、 2の画像 2
    • Remove the keycaps by evenly lifting up each key. Using a spare credit card to lift the south end of the key and my finger from the north end of the key helps remove the keys quickly.
    • The switches are Kailh switches that are soldered to the board.
    FixBotに聞いてみる
    コメントを追加
  2. Disassembling Logitech G515 Lightspeed TKL, Remove 2 back screws behind rubber feet: 手順 2、 1の画像 1
    • Remove the two rubber feet at the top on the backside. Using a heatgun/hairdryer helps soften the adhesive when removing the rubber feet.
    • Removing the bottom 3 rubber feet is not necessary.
    FixBotに聞いてみる
    コメントを追加
  3. Disassembling Logitech G515 Lightspeed TKL, Remove battery cover plate: 手順 3、 3の画像 1 Disassembling Logitech G515 Lightspeed TKL, Remove battery cover plate: 手順 3、 3の画像 2 Disassembling Logitech G515 Lightspeed TKL, Remove battery cover plate: 手順 3、 3の画像 3
    • Remove the "battery" cover sticker. Note that mine is a wired G515. Mine came off in 2 pieces (1 is a sticker and another is a thick plastic film). Using a hairdryer/heat gun helps.
    • Remove the 2 screws from the "battery" cover/plate.
    • Then remove the "battery" cover plate.
    FixBotに聞いてみる
    コメントを追加
  4. Disassembling Logitech G515 Lightspeed TKL, Peel keyboard sticker/backing: 手順 4、 1の画像 1
    • Remove the sticker/backing from the front of the keyboard. I started from a corner. You will need to use a hairdryer/heat gun to soften the adhesive. Don't concentrate the heat in one area for too long as it melts fairly quickly.
    • Be careful when removing the sticker/backing as it creases easily and will be noticeable when reinstalling it later. Mine has vertical lines as a result of me pulling the sticker/backing straight up as a means to remove it from the keyboard.
    FixBotに聞いてみる
    コメントを追加
  5. Disassembling Logitech G515 Lightspeed TKL, Remove front keyboard screws: 手順 5、 1の画像 1
    • Remove the Phillip head screws from the front of the keyboard.
    FixBotに聞いてみる
    コメントを追加
  6. Disassembling Logitech G515 Lightspeed TKL, Remove screws from back of board: 手順 6、 1の画像 1
    • Remove the Phillip head screws. Keep in mind that these screws are not like the ones from the front of the keyboard. The top two on the backside are the silver ones and the lower/middle one is a shorter black pan head screw.
    FixBotに聞いてみる
    コメントを追加
  7. Disassembling Logitech G515 Lightspeed TKL, Removing back plate of keyboard: 手順 7、 2の画像 1 Disassembling Logitech G515 Lightspeed TKL, Removing back plate of keyboard: 手順 7、 2の画像 2
    • Remove the back plate of the keyboard.
    • This is what the front of the back plate looks like when removed.
    FixBotに聞いてみる
    コメントを追加
  8. Disassembling Logitech G515 Lightspeed TKL, Remove board: 手順 8、 3の画像 1 Disassembling Logitech G515 Lightspeed TKL, Remove board: 手順 8、 3の画像 2 Disassembling Logitech G515 Lightspeed TKL, Remove board: 手順 8、 3の画像 3
    • Pull the board out from the keyboard casing/frame.
    FixBotに聞いてみる
    コメントを追加
  9. Disassembling Logitech G515 Lightspeed TKL, Extra pictures of board (1): 手順 9、 3の画像 1 Disassembling Logitech G515 Lightspeed TKL, Extra pictures of board (1): 手順 9、 3の画像 2 Disassembling Logitech G515 Lightspeed TKL, Extra pictures of board (1): 手順 9、 3の画像 3
    • Extra pictures of board (1)
    FixBotに聞いてみる
    コメントを追加
  10. Disassembling Logitech G515 Lightspeed TKL, Extra pictures of board (2): 手順 10、 3の画像 1 Disassembling Logitech G515 Lightspeed TKL, Extra pictures of board (2): 手順 10、 3の画像 2 Disassembling Logitech G515 Lightspeed TKL, Extra pictures of board (2): 手順 10、 3の画像 3
    • Extra pictures of board (2)
    FixBotに聞いてみる
    コメントを追加
  11. Disassembling Logitech G515 Lightspeed TKL, Extra pictures of board (3): 手順 11、 2の画像 1 Disassembling Logitech G515 Lightspeed TKL, Extra pictures of board (3): 手順 11、 2の画像 2
    • Extra pictures of board (3)
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
AyeVictor
メンバー登録日: 12/08/25
193 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 20
過去 30 日: 98
今までの合計 638
