メインコンテンツにスキップ
Disassembling Lacie petit 500GB n2870 ABY25 Hard drive
必要な工具と部品
  1. Disassembling Lacie petit 500GB n2870 ABY25 Hard drive, Disassembling Lacie petit 500GB n2870 ABY25 Hard drive: 手順 1、 2の画像 1 Disassembling Lacie petit 500GB n2870 ABY25 Hard drive, Disassembling Lacie petit 500GB n2870 ABY25 Hard drive: 手順 1、 2の画像 2
    • Using a fingernail or other tool, pry out the indicator light (shown on the far left here). You will find that it is actually a small, soft plastic plug
  2. Disassembling Lacie petit 500GB n2870 ABY25 Hard drive: 手順 2、 1の画像 1
    • Insert the handle end of the 2mm allen key into the hole left in step one. You may have to wiggle it around until it fits into the concealed bolt. Unscrew it counter-clockwize 18 turns. If you do it more than that, a piece will fall out inside the case, but it is no problem to screw it back on.
    • The internals will now easily slide out of either end of the case.
  3. Disassembling Lacie petit 500GB n2870 ABY25 Hard drive: 手順 3、 1の画像 1
    • You can now see what we have done. Unscrewing the screw, which you can see on the left, has decompressed the black rubber bar, so it no longer presses on the case, allowing it to slide freely.
    • (Note: that drive is not the correct hard drive: that one was in the freezer, chilling off to see if I can get data off it.)
  4. Disassembling Lacie petit 500GB n2870 ABY25 Hard drive: 手順 4、 1の画像 1
    • To remove the drive, peel off the thin rubber strap shown here first. This rubber strap has knobs on it that fit into the screw holes in the drive.
    • Then pry off the plastic moulding from the left-hand end, and slide the drive out
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Robert Backhaus
メンバー登録日: 02/20/12
312 ポイント
1ガイドが承認済み
3 件のコメント
Well done
I have plenty HD LaCie ....
And sooner or later we will need your help
Giuseppedegioia - 返信
Merci, peut-être qu’une traduction pourrait être utile pour d’autres personnes
Nicolas ELDEVES - 返信
Thank you so much!
Johnny Doensy - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 40
今までの合計 15,037
