はじめに
The guide is designed specifically for the LG Vortex phone. This guide gives detailed instructions on the removal of the back case and the face from the frame.
必要な工具と部品
Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
Remove the back cover and set it to the side.
Use the precision screwdriver to remove the 6 screws along the edges of the phone.
There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
Can you tell me who I or how to get the part that I need?
Hey it's the guy who has the V22 Vortex.That needs the chargring housing. I asked if anyone could possibly steer me in the right direction,as to where and how to get the part.But I know Just thought you AhFuck you.
Use the blue plastic opening tool to remove the back frame from the rest of the phone.
Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
Pry your way around the entire phone to separate the face from the frame.
ModelV22 Vortex. I need the charging port hole assembly.
Ok I have aV22 Vortex.Or should I say.I need the charging plug in assembly.C charger port.I'm sure I didn't say that right.But if needed I will send a picture of it.
2 の人々がこのガイドを完成させました。
