メインコンテンツにスキップ
Disassembling LG Vortex
必要な工具と部品
  1. Disassembling LG Vortex, Power down the Phone: 手順 1、 1の画像 1
    • Power the phone off
    • The power button is located on top of the phone
  2. Disassembling LG Vortex, Remove the Back Cover: 手順 2、 3の画像 1 Disassembling LG Vortex, Remove the Back Cover: 手順 2、 3の画像 2 Disassembling LG Vortex, Remove the Back Cover: 手順 2、 3の画像 3
    • Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
    • Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
    • Remove the back cover and set it to the side.
  3. Disassembling LG Vortex: 手順 3、 1の画像 1
    • Remove the battery using the blue plastic opening tool.
    • There is a small thumbnail ridge at the top left corner of the battery for ease of removal.
    • Put the battery aside.
  4. Disassembling LG Vortex, Unscrew the Back Frame: 手順 4、 2の画像 1 Disassembling LG Vortex, Unscrew the Back Frame: 手順 4、 2の画像 2
    • All screws are the same size screwdriver head #00
    • Use the precision screwdriver to remove the 6 screws along the edges of the phone.
    • There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
    • Place the screws in a container to ensure they aren't lost.
  5. Disassembling LG Vortex, Remove the Back Frame: 手順 5、 3の画像 1 Disassembling LG Vortex, Remove the Back Frame: 手順 5、 3の画像 2 Disassembling LG Vortex, Remove the Back Frame: 手順 5、 3の画像 3
    • Use the blue plastic opening tool to remove the back frame from the rest of the phone.
    • Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
    • Pry your way around the entire phone to separate the face from the frame.
終わりに
2 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Jen
メンバー登録日: 02/13/14
22 ポイント
3のガイドは作成済み
チーム
Ohio State, Team 1-3, Buehl Spring 2014 Ohio State, Team 1-3, Buehl Spring 2014人のメンバー
OSU-BUEHL-S14S1G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 24
過去 30 日: 96
今までの合計 4,076
