メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide shows how to disassemble the rear casing on a LG 440G to access the electronics.
This disassembly requires 2 tools, a Phillips #00 screw driver and an opening tool.
パーツ
パーツは指定されていません。
  1. Power phone off by pressing and holding red button.
    • Power phone off by pressing and holding red button.
  2. Flip over phone to expose the rear.
    • Flip over phone to expose the rear.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Slide rear cover downward and lift off.  You can now access the battery.
    • Slide rear cover downward and lift off. You can now access the battery.
  5. Gently lift battery from bottom.  Battery should lift out easily.
    • Gently lift battery from bottom. Battery should lift out easily.
  6. Use a Phillips #00 screw driver to remove six screws.
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  7. Run the plastic opening tool along edge of phone to release the casing cover. Lift  the casing cover.
    • Run the plastic opening tool along edge of phone to release the casing cover.
    • Lift the casing cover.
終わりに
Emily Class
メンバー登録日: 2015年02月17日
104 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-1, Buehl Winter 2015 Ohio State, Team 1-1, Buehl Winter 2015人のメンバー
OSU-BUEHL-W15S1G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 33
今までの合計 1,021
