メインコンテンツにスキップ
Disassembling Kodak Easyshare C813 Front Cover
必要な工具と部品
  1. Disassembling Kodak Easyshare C813 Front Cover, Battery: 手順 1、 1の画像 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Disassembling Kodak Easyshare C813 Front Cover: 手順 2、 3の画像 1 Disassembling Kodak Easyshare C813 Front Cover: 手順 2、 3の画像 2 Disassembling Kodak Easyshare C813 Front Cover: 手順 2、 3の画像 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Disassembling Kodak Easyshare C813 Front Cover, Back Cover: 手順 3、 1の画像 1
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
  4. Disassembling Kodak Easyshare C813 Front Cover: 手順 4、 1の画像 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Disassembling Kodak Easyshare C813 Front Cover: 手順 5、 3の画像 1 Disassembling Kodak Easyshare C813 Front Cover: 手順 5、 3の画像 2 Disassembling Kodak Easyshare C813 Front Cover: 手順 5、 3の画像 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Disassembling Kodak Easyshare C813 Front Cover: 手順 6、 3の画像 1 Disassembling Kodak Easyshare C813 Front Cover: 手順 6、 3の画像 2 Disassembling Kodak Easyshare C813 Front Cover: 手順 6、 3の画像 3
    この手順で使用する道具:
    Phillips #00 Screwdriver
    $5.49
    購入する
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Disassembling Kodak Easyshare C813 Front Cover: 手順 7、 3の画像 1 Disassembling Kodak Easyshare C813 Front Cover: 手順 7、 3の画像 2 Disassembling Kodak Easyshare C813 Front Cover: 手順 7、 3の画像 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Disassembling Kodak Easyshare C813 Front Cover: 手順 8、 3の画像 1 Disassembling Kodak Easyshare C813 Front Cover: 手順 8、 3の画像 2 Disassembling Kodak Easyshare C813 Front Cover: 手順 8、 3の画像 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Disassembling Kodak Easyshare C813 Front Cover, Front Cover: 手順 9、 2の画像 1 Disassembling Kodak Easyshare C813 Front Cover, Front Cover: 手順 9、 2の画像 2
    • Open the battery door.
  10. Disassembling Kodak Easyshare C813 Front Cover: 手順 10、 3の画像 1 Disassembling Kodak Easyshare C813 Front Cover: 手順 10、 3の画像 2 Disassembling Kodak Easyshare C813 Front Cover: 手順 10、 3の画像 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Disassembling Kodak Easyshare C813 Front Cover: 手順 11、 1の画像 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
ゴール
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Susan Marano
メンバー登録日: 04/15/10
336 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S24G22
4 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 3,887
