メインコンテンツにスキップ
Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover
必要な工具と部品
  1. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: 手順 1、 2の画像 1 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: 手順 1、 2の画像 2
    • Using a spudger, gently pry off the aluminum drip ring.
  2. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 手順 2、 1の画像 1
    • Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
  3. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 手順 3、 2の画像 1 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 手順 3、 2の画像 2
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
  4. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 手順 4、 1の画像 1
    • Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  5. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 手順 5、 1の画像 1
    • Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  6. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 手順 6、 2の画像 1 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 手順 6、 2の画像 2
    • Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
  7. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 手順 7、 2の画像 1 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 手順 7、 2の画像 2
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
  8. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 手順 8、 1の画像 1
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside-down to prevent grease from leaking out.
終わりに
36 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Chris Gonzales
メンバー登録日: 10/12/14
1,626 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 14-28, Maness Fall 2014 Cal Poly, Team 14-28, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S14G28
4 メンバー
22のガイドは作成済み
27 Guide Comments
Well fine job! Just finished and t works!!!
James Anderson - 返信
Instruccion is exelent but I veleave the problem is electric. can you give aidea. dhe machine does’nt work at all
Aristides Aleman - 返信
Thank you! I'm repainting my white mixer a deep cherry red gloss to match my kitchen. These mixers can last 20+ years, if you take care of them. But, who wants the same color kitchen for that long? Bonus: saved $50+ by painting it the color I wanted, rather than pay the extra for a mixer from the colored choices.
Heather Schrader - 返信
Do the motor housing sometimes become to hard to remove? I followed all the steps yet it still acts as if something inside the housing is keeping it from coming off.
Royce M - 返信
Nothing else, only the planetary assembly, and the 9 big housing screws. Once those are off, it can take a lot of jiggling and persistence, mostly because there’s a vacuum between the vertical shaft and the bushing inside. Remember to loosen the cord in case to prevent yanking it accidentally when the cover comes off.
Ariel Cornejo -
コメントを追加
統計データ:
過去 24時間: 34
過去 7 日: 264
過去 30 日: 1,208
今までの合計 111,474
