メインコンテンツにスキップ
はじめに
These instructions will demonstrate how to remove the faceplate from the KDDI Kyocera A5521K.
パーツ
パーツは指定されていません。
  1. Turn the phone over to expose the battery cover. Apply pressure to the back of the battery cover to slide it down. The battery cover is now separate from the phone.
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Remove the battery by pushing it up and out from the bottom. The battery, cover, and phone should now be separated. The battery, cover, and phone should now be separated.
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone. Beneath the covers are screws. Beneath the covers are screws.
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  4. Remove the screws using a Y0 screwdriver.
    • Remove the screws using a Y0 screwdriver.
  5. Use the iPod pry tool to remove the outer screen. Two screws are now visible. Be careful not to crack the screen upon removal.  It is adhered strongly to the phone.
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  6. Use the Y0 screwdriver to remove the screws.
    • Use the Y0 screwdriver to remove the screws.
  7. Use the iPod pry tool to loosen the faceplate from the phone. Slide the pry tool along the entire crease of the faceplate to completely detach it.
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  8. Separate the faceplate from the phone. Separate the faceplate from the phone. Separate the faceplate from the phone.
    • Separate the faceplate from the phone.
まとめ
ある他の人がこのガイドを完成しました。
Dominic Grisafe
メンバー登録日: 2010年04月15日
157 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 28-25, Regan Spring 2010 Cal Poly, Team 28-25, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S28G25
4 メンバー
20のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,581
