この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The external shell protects the delicate internal components of the projector from dust, debris, and shock. It is secured with many screws to keep it securely in place, and it must be removed to do any repairs on the inside of the device. As the shell houses the exterior projector buttons, if any of them are damaged, and the button circuit board is intact, replacing the top of the shell will restore the projector to working order.
必要な工具と部品
Place the projector on its back (buttons down) with the lens facing away from you.
Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
Flip the projector over and turn around so that the lens faces you.
Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
ある他の人がこのガイドを完成しました。
