この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The plastic edge cover needs to be removed to get to some components.
必要な工具と部品
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
