メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling IBM ThinkPad A30 Upper Case
必要な工具と部品
  1. Disassembling IBM ThinkPad A30 Upper Case, Battery: 手順 1、 2の画像 1 Disassembling IBM ThinkPad A30 Upper Case, Battery: 手順 1、 2の画像 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: 手順 2、 3の画像 1 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: 手順 2、 3の画像 2 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: 手順 2、 3の画像 3
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
  3. Disassembling IBM ThinkPad A30 Upper Case, Upper Case: 手順 3、 1の画像 1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  4. Disassembling IBM ThinkPad A30 Upper Case: 手順 4、 1の画像 1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  5. Disassembling IBM ThinkPad A30 Upper Case: 手順 5、 2の画像 1 Disassembling IBM ThinkPad A30 Upper Case: 手順 5、 2の画像 2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  6. Disassembling IBM ThinkPad A30 Upper Case: 手順 6、 3の画像 1 Disassembling IBM ThinkPad A30 Upper Case: 手順 6、 3の画像 2 Disassembling IBM ThinkPad A30 Upper Case: 手順 6、 3の画像 3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  7. Disassembling IBM ThinkPad A30 Upper Case: 手順 7、 3の画像 1 Disassembling IBM ThinkPad A30 Upper Case: 手順 7、 3の画像 2 Disassembling IBM ThinkPad A30 Upper Case: 手順 7、 3の画像 3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  8. Disassembling IBM ThinkPad A30 Upper Case: 手順 8、 2の画像 1 Disassembling IBM ThinkPad A30 Upper Case: 手順 8、 2の画像 2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  9. Disassembling IBM ThinkPad A30 Upper Case: 手順 9、 3の画像 1 Disassembling IBM ThinkPad A30 Upper Case: 手順 9、 3の画像 2 Disassembling IBM ThinkPad A30 Upper Case: 手順 9、 3の画像 3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Alan
メンバー登録日: 10/07/10
380 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010人のメンバー
CPSU-AMIDO-F10S4G44
4 メンバー
26のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 23
過去 30 日: 65
今までの合計 2,507
