Flip the ThinkPad over so that it is upside down.
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
Rotate the ThinkPad so that the hard drive bay is facing you.
Remove the black cover to reveal a 14.8mm screw.
Remove the uncovered screw with a Phillips #0 screwdriver.
Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
Lift the front end of the keyboard as shown.
Using your fingers, remove the black film cover.
Remove the 5.6mm screw on the left side of the three-pronged connector.
Remove the other two 16.7mm screws.
Lift and remove connector.
Place the laptop so that the LCD is facing you again.
Gently lift the LCD monitor up and out.
Remove the black plastic tab.
Be careful not to pull too hard. There is a cable attached to the fan.
Lift the fan/heatsink assembly up.
Locate the fan power cable and pull upwards near the connector.
Remove the fan/heatsink assembly.
Turn the laptop over so the battery is facing you.
Locate the modem and ethernet card bay.
Remove the two 5.3mm cover screws.
Gently lift the cover.
Remove the four 9.1mm screws attached to the modem and ethernet cards.
When lifting the cards, be careful not to rip out the cables!
Gently lift the modem and ethernet cards.
Turn the laptop over again and orient it as shown.
Lift the left side of the floppy disk bay and and pull it out.
The black lever will pop out.
Locate the CD Drive Bay
Remove the three 5.6mm screws.
Remove the 16mm screw.
Lift the right side and pull the CD drive bay out.
Remove the 5.6mm screws on each speaker.
Pull the right speaker out, making sure there is still slack in the wire.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
