必要な工具と部品
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
Remove the highlighted screw with a Phillips #1 screwdriver.
Pull the hard drive out.
Hold the laptop in the same orientation as the picture. Then, locate the switch immediately above and to the left of the drive.
Slide the switch to the right. A black plastic tab will pop out.
Pull the plastic tab to expose the CD drive.
If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the CD drive, please check the corresponding entry in the troubleshooting page.
There is a switch located just above and to the right of the drive.
Slide the switch to the right. A small, black tab will pop out.
Locate the floppy drive bay.
Remove the four 5.6mm screws.
Remove the 16mm screw.
3 の人々がこのガイドを完成させました。
