Flip the ThinkPad over so that it is upside down.
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
Rotate the ThinkPad so that the hard drive bay is facing you.
Remove the black cover to reveal a 14.8mm screw.
Remove the uncovered screw with a Phillips #0 screwdriver.
Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
Lift the front end of the keyboard as shown.
Using your fingers, remove the black film cover.
Remove the 5.6mm screw on the left side of the three-pronged connector.
Remove the other two 16.7mm screws.
Lift and remove connector.
Place the laptop so that the LCD is facing you again.
Gently lift the LCD monitor up and out.
Remove the black plastic tab.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
