メインコンテンツにスキップ
Disassembling HP Printer printer cover
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
    • Lift open the scanner cover.
    • Gently pry off the scanner cover support arm. This is the scariest part as the arm is all plastic. There is a small nob projecting into the path of the slider in the middle of the arm. Hold the cover open to minimize contact with the support arm while prying.
    • Carefully remove part of the printer badge on the front right hand side of the printer. Underneath you will expose the first of three hidden screws.
    • On the front left-hand side of the printer is the monitor / display. This is clipped into the plastic printer cover. Reach underneath to squeeze the clips so you can gently pull up and out the three clips
    • Disconnect the flat cable to the display unit and set aside.
    • Take your screwdriver and remove the two screws uncovered by the removed display.
    • Remove the two screws on the left hand side of the printer cover
    • Remove the two screws on the right hand side of the printer cover.
    • Remove the two screws at the back of the printer holding the scanner main hinges in place.
    • Place a support behind the printer with a soft cover (towel will do) to place the scanner.
    • Unhinge the scanner and carefully place on the towel behind the printer (as the cable is still attached).
    • Remove the printer cover.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Gerold Rupprecht
メンバー登録日: 05/26/13
155 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,163
