はじめに
A side panel is located on each side of the device. The right side panel, containing the button(s), controls the track being selected as well as the volume of the device. There are no prerequisites required for this guide.
  • A pry bar is necessary to remove the panel.
パーツ
パーツは必要ありません。
  1. Use the plastic opening tool.
    • Use the plastic opening tool.
    • Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. The side panel can now be detached using your fingers. The buttons can be dislodged by turning the panel over and shaking it, if necessary. The buttons can be dislodged by turning the panel over and shaking it, if necessary.
    • The side panel can now be detached using your fingers.
    • The buttons can be dislodged by turning the panel over and shaking it, if necessary.
まとめ
After disassembling, the device and its components should look similar to that depicted in the cover image (top right of page).
Alexander
メンバー登録日: 2012年03月09日
101 ポイント
9のガイドは作成済み
チーム
Clemson, Team 15-3, Benson Spring 2012 Clemson, Team 15-3, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S15G3
3 メンバー
9のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 817
