メインコンテンツにスキップ
Disassembling General Electric Telephone 2-9710A Handset
必要な工具と部品
  1. Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: 手順 1、 2の画像 1 Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: 手順 1、 2の画像 2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Disassembling General Electric Telephone 2-9710A Handset: 手順 2、 3の画像 1 Disassembling General Electric Telephone 2-9710A Handset: 手順 2、 3の画像 2 Disassembling General Electric Telephone 2-9710A Handset: 手順 2、 3の画像 3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: 手順 3、 2の画像 1 Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: 手順 3、 2の画像 2
    • Remove the plastic cover with a plastic opening tool by gently sliding the tool underneath the plastic and pry the cover off.
  4. Disassembling General Electric Telephone 2-9710A Handset: 手順 4、 1の画像 1
    • Remove the paper with a plastic opening tool by gently sliding the tool underneath and prying the paper away from the phone.
  5. Disassembling General Electric Telephone 2-9710A Handset: 手順 5、 2の画像 1 Disassembling General Electric Telephone 2-9710A Handset: 手順 5、 2の画像 2
    • Remove the rubber stopper with a plastic opening tool by gently sliding the tool underneath and pry away from the phone.
  6. Disassembling General Electric Telephone 2-9710A Handset: 手順 6、 2の画像 1 Disassembling General Electric Telephone 2-9710A Handset: 手順 6、 2の画像 2
    • Remove the two 2.1 mm screws with a Phillips #1 screwdriver.
  7. Disassembling General Electric Telephone 2-9710A Handset: 手順 7、 1の画像 1
    • Pull apart the handset by pulling the top shell away from the other half of the phone.
  8. Disassembling General Electric Telephone 2-9710A Handset: 手順 8、 2の画像 1 Disassembling General Electric Telephone 2-9710A Handset: 手順 8、 2の画像 2
    • Remove 3 screws attaching the motherboard to shell.
    • Remove the 13 mm screw with a Philips #1 screwdriver.
    • Remove the two 13 mm screws with washers with a Philips #1 screwdriver.
  9. Disassembling General Electric Telephone 2-9710A Handset: 手順 9、 2の画像 1 Disassembling General Electric Telephone 2-9710A Handset: 手順 9、 2の画像 2
    • Slide the phone jack out from the shell by gently lifting up the female phone jack connector.
  10. Disassembling General Electric Telephone 2-9710A Handset: 手順 10、 1の画像 1
    • Without removing the motherboard completely, pull up slightly and pivot the motherboard out of the shell.
    • Be careful not to pull the connectors out.
終わりに
作成者
12人の作成者と共同で作成されました。
Alles Rebel
メンバー登録日: 09/20/12
72 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 16-59, Forte Fall 2012 Cal Poly, Team 16-59, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S16G59
4 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 25
今までの合計 2,715
