この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
A step-by-step guide to removing the outer case of the Garmin Nuvi 680.
必要な工具と部品
Flip open the antenna on the back of the device.
Remove the two screws on the antenna cover using a T5 Torx screwdriver.
These screws are 4.42 mm long.
3 の人々がこのガイドを完成させました。
2 件のコメント
This guide works for the Garmin Nuvi 660 and 670 as well.
great instructions thank you! most of it also works for the NUVI 350, this one has an extra screw that holds the circuit board, and the connectors are different. Fixed the on/off button that broke of the soldering tips by re-soldering and adding some support at the back of the switch so this can't happen again.
