メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling GD Midea FT30-3D AC Power Cord
必要な工具と部品
  1. Disassembling GD Midea FT30-3D AC Power Cord, Bottom Base: 手順 1、 1の画像 1
    • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
  2. Disassembling GD Midea FT30-3D AC Power Cord: 手順 2、 2の画像 1 Disassembling GD Midea FT30-3D AC Power Cord: 手順 2、 2の画像 2
    • Locate the gray base support release tabs found on either side pictured in the first image.
    • There are release tabs on each side of the base.
    • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
  3. Disassembling GD Midea FT30-3D AC Power Cord: 手順 3、 1の画像 1
    • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
    • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
  4. Disassembling GD Midea FT30-3D AC Power Cord: 手順 4、 1の画像 1
    • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
  5. Disassembling GD Midea FT30-3D AC Power Cord: 手順 5、 1の画像 1
    • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
    • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
  6. Disassembling GD Midea FT30-3D AC Power Cord: 手順 6、 1の画像 1
    • Once all five screws have been removed the base cover should fall right off with out any effort.
    • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
  7. Disassembling GD Midea FT30-3D AC Power Cord, AC Power Cord: 手順 7、 1の画像 1
    • Remove the two 15 mm Phillips screws on the retention plate.
    • The tan retention plate will fall off once the screws are removed.
  8. Disassembling GD Midea FT30-3D AC Power Cord: 手順 8、 1の画像 1
    • Take the 1.5 mm Flathead Screwdriver, or any thin elongated tool that fits into the semi-circular holes along side the AC power cord white wire. Press into the hole gently to release the grip on the wire.
    • The AC power cord wire should release with ease if done properly.
  9. Disassembling GD Midea FT30-3D AC Power Cord: 手順 9、 1の画像 1
    • Cut the existing cable tie bundling the other AC power cord, red, orange, gray, and blue wires together.
    • Remove or cut the crimp connector connecting the blue wire and the AC power cord wire.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Chris Hartley
メンバー登録日: 10/04/12
444 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S24G28
4 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 33
今までの合計 932
