メインコンテンツにスキップ
Disassembling Fujifilm Endeavor 100ix Outer Casing
必要な工具と部品
  1. Disassembling Fujifilm Endeavor 100ix Outer Casing, Outer Casing: 手順 1、 1の画像 1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 2、 1の画像 1
    • Locate the battery door.
  3. Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 3、 1の画像 1
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  4. Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 4、 1の画像 1
    • Remove the battery from the camera by pulling the battery door outwards.
  5. Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 5、 1の画像 1
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  6. Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 6、 2の画像 1 Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 6、 2の画像 2
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  7. Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 7、 1の画像 1
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
  8. Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 8、 1の画像 1
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
  9. Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 9、 1の画像 1
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  10. Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 10、 1の画像 1
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  11. Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 11、 2の画像 1 Disassembling Fujifilm Endeavor 100ix Outer Casing: 手順 11、 2の画像 2
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
終わりに
作成者
5人の作成者と共同で作成されました。
Eric Nicolai
メンバー登録日: 01/10/11
679 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 13-5, Forte Winter 2011 Cal Poly, Team 13-5, Forte Winter 2011人のメンバー
CPSU-FORTE-W11S13G5
5 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 1,356
