メインコンテンツにスキップ
Disassembling Flip Video Circuit Board
必要な工具と部品
  1. Disassembling Flip Video Circuit Board, Outer Shell: 手順 1、 2の画像 1 Disassembling Flip Video Circuit Board, Outer Shell: 手順 1、 2の画像 2
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Disassembling Flip Video Circuit Board: 手順 2、 1の画像 1
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Disassembling Flip Video Circuit Board: 手順 3、 2の画像 1 Disassembling Flip Video Circuit Board: 手順 3、 2の画像 2
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Disassembling Flip Video Circuit Board: 手順 4、 1の画像 1
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Disassembling Flip Video Circuit Board: 手順 5、 1の画像 1
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Disassembling Flip Video Circuit Board, Circuit Board: 手順 6、 1の画像 1
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
  7. Disassembling Flip Video Circuit Board: 手順 7、 1の画像 1
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
  8. Disassembling Flip Video Circuit Board: 手順 8、 1の画像 1
    • Disconnect the USB port cable from the back side of the circuit board.
  9. Disassembling Flip Video Circuit Board: 手順 9、 1の画像 1
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Elizabeth
メンバー登録日: 04/15/10
100 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S26G21
4 メンバー
12のガイドは作成済み
コメント 1 件
Thank you. Where is the reset button on these first generation Flip Videos (mine doesn’t have one visible on outside, must be on inside.
sherrygray - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,221
