メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling External Storage Hard drive
必要な工具と部品
  1. Disassembling External Storage Hard drive, Disassembling External Storage Hard drive: 手順 1、 1の画像 1
    • Remove the screw marked with a red arrow to access hidden top tab.
    • Use a pointy tool to press the two tabs around the USB 3 connector. These are accessible via the holes marked with orange arrows.
    • You can slightly lift the back edge up to help free the tabs as you press them in. It doesn't take much to release them, so don't push too hard.
    FixBotに聞いてみる
    コメントを追加
  2. Disassembling External Storage Hard drive: 手順 2、 2の画像 1 Disassembling External Storage Hard drive: 手順 2、 2の画像 2
    • Along the top edge are the tabs marked in the first picture by the red circles. Use a thin-bladed screw driver to catch and pull back these tabs slightly to release the cover on this edge.
    • Lift on the cover slightly to ensure the tabs are released.
    FixBotに聞いてみる
    コメントを追加
  3. Disassembling External Storage Hard drive: 手順 3、 2の画像 1 Disassembling External Storage Hard drive: 手順 3、 2の画像 2
    • The front of the case has two tabs, marked by red arrows in the first pic. Repeat the process of using the screwdriver to gently release the tabs.
    • Continuing gently lifting on the cover while releasing the hidden tabs.
    FixBotに聞いてみる
    コメントを追加
  4. Disassembling External Storage Hard drive: 手順 4、 1の画像 1
    • The 3 red arrows indicate the hidden tabs on the last side. Repeat the screwdriver technique from the last two steps.
    • You should be able to remove the cover after all tabs have been released.
    FixBotに聞いてみる
    コメントを追加
  5. Disassembling External Storage Hard drive: 手順 5、 2の画像 1 Disassembling External Storage Hard drive: 手順 5、 2の画像 2
    • With the cover removed, the hard drive should be exposed--refer to the first picture to locate it.
    • Use the flat blade screwdriver to gently pry out the plastic case the hard drive sits in.
    • The hard drive is only held in the case with rubber bumper style mounts, and will come out with a little finger pulling.
    FixBotに聞いてみる
    コメントを追加
  6. Disassembling External Storage Hard drive: 手順 6、 3の画像 1 Disassembling External Storage Hard drive: 手順 6、 3の画像 2 Disassembling External Storage Hard drive: 手順 6、 3の画像 3
    • Remove hard drive from plastic case, flip over, and remove the two screws marked by red circles.
    • You will be left with the board and interface (seen in 3rd pic), ready to install your new hard drive.
    • Installation is the reverse of removal! Enjoy!
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
10 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
HWgeek
メンバー登録日: 12/03/12
307 ポイント
1ガイドが承認済み
5件のガイドコメント
Nice, easy and concise ‘how-to’. You made my task so much easier. Thank you!
Brian Puffer - 返信 共有
Thanks..got the job done.
Jeff Willard - 返信 共有
thank you for the blog. keep it up.
Sunil Das Shrestha - 返信 共有
thanks.... just the job.
Stephen Foxall - 返信 共有
My God I would never have been able to get this thing apart intact without this guide, THANKS !!
James McCarthy - 返信 共有
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 31
過去 30 日: 139
今までの合計 24,777
