メインコンテンツにスキップ
Disassembling Ericsson CF 388 Microphone
必要な工具と部品
  1. Disassembling Ericsson CF 388 Microphone, Disassembling Ericsson CF 388 Battery: 手順 1、 3の画像 1 Disassembling Ericsson CF 388 Microphone, Disassembling Ericsson CF 388 Battery: 手順 1、 3の画像 2 Disassembling Ericsson CF 388 Microphone, Disassembling Ericsson CF 388 Battery: 手順 1、 3の画像 3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Microphone, Phone Casing: 手順 2、 3の画像 1 Disassembling Ericsson CF 388 Microphone, Phone Casing: 手順 2、 3の画像 2 Disassembling Ericsson CF 388 Microphone, Phone Casing: 手順 2、 3の画像 3
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
  3. Disassembling Ericsson CF 388 Microphone: 手順 3、 3の画像 1 Disassembling Ericsson CF 388 Microphone: 手順 3、 3の画像 2 Disassembling Ericsson CF 388 Microphone: 手順 3、 3の画像 3
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
  4. Disassembling Ericsson CF 388 Microphone: 手順 4、 2の画像 1 Disassembling Ericsson CF 388 Microphone: 手順 4、 2の画像 2
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
  5. Disassembling Ericsson CF 388 Microphone, Keypad Support Skeleton: 手順 5、 2の画像 1 Disassembling Ericsson CF 388 Microphone, Keypad Support Skeleton: 手順 5、 2の画像 2
    • After removing the battery casing and taking apart the phone casing, the keypad is held in with a plastic skeleton structure as shown.
  6. Disassembling Ericsson CF 388 Microphone: 手順 6、 3の画像 1 Disassembling Ericsson CF 388 Microphone: 手順 6、 3の画像 2 Disassembling Ericsson CF 388 Microphone: 手順 6、 3の画像 3
    • To remove the plastic skeleton structure, locate the tab at the top of the phone near the LCD display screen.
    • Carefully remove the skeleton by holding on the front phone casing with one hand and pull tab with your index finger while having your thumb at the bottom of the phone as shown.
  7. Disassembling Ericsson CF 388 Microphone, Microphone: 手順 7、 1の画像 1
    • After removing the keypad skeleton, the microphone becomes accessible.
    • Locate the microphone at bottom of the phone, below the keypad, as indicated by the red circle.
  8. Disassembling Ericsson CF 388 Microphone: 手順 8、 3の画像 1 Disassembling Ericsson CF 388 Microphone: 手順 8、 3の画像 2 Disassembling Ericsson CF 388 Microphone: 手順 8、 3の画像 3
    • To remove the microphone, carefully poke out the microphone through the front hole with a paper clip.
    • Slowly and carefully, push the microphone out.
    • Note: Do not push too hard as it could damage or fling the microphone. You don't want to lose it!
終わりに
作成者
5人の作成者と共同で作成されました。
Niccolas Tones
メンバー登録日: 03/09/12
60 ポイント
9のガイドは作成済み
チーム
Clemson, Team 1-1, Benson Spring 2012 Clemson, Team 1-1, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S1G1
3 メンバー
21のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 972
