メインコンテンツにスキップ
Epson Stylus Photo 820 Top Cover Replacement
必要な工具と部品
  1. Epson Stylus Photo 820 Top Cover Replacement, Top Cover: 手順 1、 2の画像 1 Epson Stylus Photo 820 Top Cover Replacement, Top Cover: 手順 1、 2の画像 2
    • To remove the top cover of the printer, you have to first release it from several tabs.
    • This may take more than one person to complete.
    • These three are the easiest tabs to remove. They are located on the back side of the printer.
  2. Epson Stylus Photo 820 Top Cover Replacement: 手順 2、 2の画像 1 Epson Stylus Photo 820 Top Cover Replacement: 手順 2、 2の画像 2
    • Push the tab in with one of the plastic opening tools.
    • Keep the tab pushed in by leveraging the tool between the tab and the hole. Pull up on the case so that the tab doesn't lock back into place.
    • Repeat this process with the furthermost right tab, then proceed with the middle tab.
  3. Epson Stylus Photo 820 Top Cover Replacement: 手順 3、 3の画像 1 Epson Stylus Photo 820 Top Cover Replacement: 手順 3、 3の画像 2 Epson Stylus Photo 820 Top Cover Replacement: 手順 3、 3の画像 3
    • It is recommended that Steps 3 and 4 be completed simultaneously. The tabs are identical, just on opposite sides.
    • Insert the pointed end of a spudger into the hole on the bottom left corner of the printer and pry out the tab.
    • This tab is the easiest to break, so be very careful.
  4. Epson Stylus Photo 820 Top Cover Replacement: 手順 4、 2の画像 1 Epson Stylus Photo 820 Top Cover Replacement: 手順 4、 2の画像 2
    • Insert the pointed end of a spudger into the hole on the bottom right corner of the printer and pry out the tab.
  5. Epson Stylus Photo 820 Top Cover Replacement: 手順 5、 3の画像 1 Epson Stylus Photo 820 Top Cover Replacement: 手順 5、 3の画像 2 Epson Stylus Photo 820 Top Cover Replacement: 手順 5、 3の画像 3
    • The final two tabs can be more difficult to release. Viewing from the front, they are located in the back left and right corners of the printer.
    • The release points for the tabs are located in holes on the depressed area of the base (darker piece).
    • Use the pointed end of a spudger to pry out the tab.
    • Use one of the plastic tools to keep the tab pried out. Once it releases, push in towards the printer (viewing from the side) and pull up on the case.
  6. Epson Stylus Photo 820 Top Cover Replacement: 手順 6、 1の画像 1
    • All of the tabs have now been released.
    • When trying to completely remove the cover, it gets caught on these two back components. Maneuvering around these can be tricky.
    • Push the cover to the right slightly and then push it backwards (out of the screen in this picture). This should give it some wiggle room. Repeat this as necessary.
  7. Epson Stylus Photo 820 Top Cover Replacement: 手順 7、 2の画像 1 Epson Stylus Photo 820 Top Cover Replacement: 手順 7、 2の画像 2
    • Pull the cover up and off.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
dante gagliardi
メンバー登録日: 04/13/11
45 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 20-68, Walters Spring 2011 Cal Poly, Team 20-68, Walters Spring 2011人のメンバー
CPSU-WALTERS-S11S20G68
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 3,303
