メインコンテンツにスキップ
Disassembling Epson PPC650 Replacing Flash
必要な工具と部品
  1. Disassembling Epson PPC650 Replacing Flash, Case: 手順 1、 3の画像 1 Disassembling Epson PPC650 Replacing Flash, Case: 手順 1、 3の画像 2 Disassembling Epson PPC650 Replacing Flash, Case: 手順 1、 3の画像 3
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Disassembling Epson PPC650 Replacing Flash: 手順 2、 1の画像 1
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Disassembling Epson PPC650 Replacing Flash: 手順 3、 2の画像 1 Disassembling Epson PPC650 Replacing Flash: 手順 3、 2の画像 2
    • Remove 3 screws on the flat side of the camera
    • All silver screws go into the side of the camera that is silver
    • All black screws go into the side of the camera that is black
  4. Disassembling Epson PPC650 Replacing Flash: 手順 4、 1の画像 1
    • Remove 4 screws from the bottom of the camera
  5. Disassembling Epson PPC650 Replacing Flash: 手順 5、 3の画像 1 Disassembling Epson PPC650 Replacing Flash: 手順 5、 3の画像 2 Disassembling Epson PPC650 Replacing Flash: 手順 5、 3の画像 3
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
    • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
    • Use minimal force so that the plastic casing does not break
    • When separating the small silver sliding indicator for view/off/playback may fall out
    • The plastic viewing window located on the top of the camera may also become lose and fall out
  6. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 手順 6、 3の画像 1 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 手順 6、 3の画像 2 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 手順 6、 3の画像 3
    • Optional: Remove two black screws from top of camera on the flash side for more working space.
  7. Disassembling Epson PPC650 Replacing Flash: 手順 7、 1の画像 1
    • Remove clear rubber band holding flash in line with wiring.
    • Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
    • Connect new flash by soldering copper ends to their respective ends to new flash element.
終わりに
作成者
5人の作成者と共同で作成されました。
Xan Danes
メンバー登録日: 02/14/13
122 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-5, Buehl Spring 2013 Ohio State, Team 1-5, Buehl Spring 2013人のメンバー
OSU-BUEHL-S13S1G5
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 286
