はじめに
Before starting, please:
- make sure nothing is attached (such as AC adapter, USB, VGA, audio jack).
- remove any inserted SD card.
ツール
ツールは指定されていません。
パーツ
Slide the switch on the bottom of the laptop until the battery pops out.
Once the battery pops out, you can remove it.
Using forceps or tweezers, remove the two rear rubber feet to expose two hidden screws.
Using a Phillips head #00 Screwdriver, remove a total of 12 screws:
10 screws in the battery compartment.
size ph#00, approximately 3 mm long
2 screws under the rubber feet previously removed
Size ph#00, approximately 4.5 mm long
2 の人々がこのガイドを完成させました。
