メインコンテンツにスキップ
Compaq Mini 110 Hard Drive Replacement
必要な工具と部品
  1. Compaq Mini 110 Hard Drive Replacement, Battery: 手順 1、 2の画像 1 Compaq Mini 110 Hard Drive Replacement, Battery: 手順 1、 2の画像 2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
  2. Compaq Mini 110 Hard Drive Replacement: 手順 2、 3の画像 1 Compaq Mini 110 Hard Drive Replacement: 手順 2、 3の画像 2 Compaq Mini 110 Hard Drive Replacement: 手順 2、 3の画像 3
    • Push both tabs inward simultaneously and slide the battery out.
  3. Compaq Mini 110 Hard Drive Replacement, RAM: 手順 3、 2の画像 1 Compaq Mini 110 Hard Drive Replacement, RAM: 手順 3、 2の画像 2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
  4. Compaq Mini 110 Hard Drive Replacement: 手順 4、 1の画像 1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
  5. Compaq Mini 110 Hard Drive Replacement, Keyboard: 手順 5、 2の画像 1 Compaq Mini 110 Hard Drive Replacement, Keyboard: 手順 5、 2の画像 2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  6. Compaq Mini 110 Hard Drive Replacement: 手順 6、 2の画像 1 Compaq Mini 110 Hard Drive Replacement: 手順 6、 2の画像 2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
  7. Compaq Mini 110 Hard Drive Replacement: 手順 7、 2の画像 1 Compaq Mini 110 Hard Drive Replacement: 手順 7、 2の画像 2
    • Unscrew the screw for the bottom case located in the RAM compartment.
  8. Compaq Mini 110 Hard Drive Replacement: 手順 8、 2の画像 1 Compaq Mini 110 Hard Drive Replacement: 手順 8、 2の画像 2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
  9. Compaq Mini 110 Hard Drive Replacement, Hard Drive: 手順 9、 1の画像 1
    • Remove the three screws holding the panel in place.
  10. Compaq Mini 110 Hard Drive Replacement: 手順 10、 2の画像 1 Compaq Mini 110 Hard Drive Replacement: 手順 10、 2の画像 2
    • Pull up on the tab to remove the hard drive.
終わりに
15 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
alea
メンバー登録日: 10/06/10
1,405 ポイント
14のガイドは作成済み
チーム
Cal Poly, Team 22-2, Maness Fall 2010 Cal Poly, Team 22-2, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S22G2
6 メンバー
20のガイドは作成済み
2 件のコメント
still cannot remove back of my compacq mini. i have taken all screws out as told but back refuses to part.
madudman - 返信
still cannot remove back of my compact after removing all screws. are ther any more hidden clips ? mike
madudman - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 46
今までの合計 38,731
