メインコンテンツにスキップ
はじめに
This may need to be removed if the button or scroll wheel is not working.
パーツ
パーツは指定されていません。
  1. Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen. Remove the 2 screws (4.08 mm) on the other side.  One is located under the rubber USB flap. Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen.
    • Remove the 2 screws (4.08 mm) on the other side. One is located under the rubber USB flap.
    • Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Slowly pull the back cover of the camera.
  2. Android 修理キット
    交換用スクリーンやバッテリーの修理キット
    ショップを見る
    Android 修理キット
    ショップを見る
  3. Remove 2 screws from back of camera using screwdriver. Remove 2 screws holding metal side guard using screwdriver. Remove the connecting ribbon by pulling it straight out.
    • Remove 2 screws from back of camera using screwdriver.
    • Remove 2 screws holding metal side guard using screwdriver.
    • Remove the connecting ribbon by pulling it straight out.
まとめ
Ben Tupas
メンバー登録日: 2011年01月13日
317 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011人のメンバー
CPSU-FORTE-W11S13G3
5 メンバー
8のガイドは作成済み
コメントを追加する
統計データを表示:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
今までの合計 1,241
