メインコンテンツにスキップ
Disassembling Canon Powershot SD880 Logic Board
必要な工具と部品
  1. Disassembling Canon Powershot SD880 Logic Board, Back Cover: 手順 1、 3の画像 1 Disassembling Canon Powershot SD880 Logic Board, Back Cover: 手順 1、 3の画像 2 Disassembling Canon Powershot SD880 Logic Board, Back Cover: 手順 1、 3の画像 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Disassembling Canon Powershot SD880 Logic Board, Front Cover: 手順 2、 3の画像 1 Disassembling Canon Powershot SD880 Logic Board, Front Cover: 手順 2、 3の画像 2 Disassembling Canon Powershot SD880 Logic Board, Front Cover: 手順 2、 3の画像 3
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
  3. Disassembling Canon Powershot SD880 Logic Board, Top Panel: 手順 3、 2の画像 1 Disassembling Canon Powershot SD880 Logic Board, Top Panel: 手順 3、 2の画像 2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
  4. Disassembling Canon Powershot SD880 Logic Board, Logic Board: 手順 4、 1の画像 1
    • Remove 2 screws(1.75mm) using a screwdriver.
    • Detach 3 ribbons by pulling up on them. All are on the front of the camera.
  5. Disassembling Canon Powershot SD880 Logic Board: 手順 5、 2の画像 1 Disassembling Canon Powershot SD880 Logic Board: 手順 5、 2の画像 2
    • Remove the newly exposed screw(1.75mm) with screwdriver.
    • Unhinge the black tab to slide out the ribbon.
    • The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
終わりに
作成者
4人の作成者と共同で作成されました。
Juan Miguel
メンバー登録日: 01/13/11
101 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011人のメンバー
CPSU-FORTE-W11S13G3
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 2,019
