この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The LCD display can be removed and replaced if it is cracked or broken.
必要な工具と部品
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Remove the screws (2.88 mm) at the top right corner and bottom left corner of the LCD screen.
Disconnect the ribbons connecting the screen to the camera.
Lift off the screen.
