メインコンテンツにスキップ
はじめに
The LCD display can be removed and replaced if it is cracked or broken.
パーツ
パーツは指定されていません。
  1. Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen. Remove the 2 screws (4.08 mm) on the other side.  One is located under the rubber USB flap. Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen.
    • Remove the 2 screws (4.08 mm) on the other side. One is located under the rubber USB flap.
    • Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Slowly pull the back cover of the camera.
  2. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  3. Remove the screws (2.88 mm) at the top right corner and bottom left corner of the LCD screen. Disconnect the ribbons connecting the screen to the camera. Lift off the screen.
    • Remove the screws (2.88 mm) at the top right corner and bottom left corner of the LCD screen.
    • Disconnect the ribbons connecting the screen to the camera.
    • Lift off the screen.
まとめ
Ben Tupas
メンバー登録日: 2011年01月13日
317 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011人のメンバー
CPSU-FORTE-W11S13G3
5 メンバー
8のガイドは作成済み
コメント1件
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - 返信
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,161
